Warren99 Posted August 2, 2023 Share Posted August 2, 2023 Been there for a month, but I've been looking for a shifter for my AX-15, because mine came out of a YJ and has a taller shifter. Is this likely to be an ax5 or something? Regardless, what are my odds of the shifter being able to fit in mine? Link to comment Share on other sites More sharing options...
Pete M Posted August 2, 2023 Share Posted August 2, 2023 ax-15 didn't come into play until mid-89 and was only available behind the 4.0 (in Jeeps at least) the ax-5 and ax-15 have essentially nothing in common but the manufacturer. Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 2, 2023 Share Posted August 2, 2023 45 minutes ago, Pete M said: the ax-5 and ax-15 have essentially nothing in common but the manufacturer. I mean it is possible to separate the handle and stick it on an AX5 shifter tower if someone wants that taller shifter. Regardless if it’s AX4/5, you have from basically 1984-2001 XJ. Link to comment Share on other sites More sharing options...
Warren99 Posted August 2, 2023 Author Share Posted August 2, 2023 Ah ok ty. Yea I'll just cut and reweld my shifter before I take apart different ones. But if I ever happen to find an ax-15 on a XJ/MJ I'll just grab that Link to comment Share on other sites More sharing options...
