Hello, My name is Steven.
This is my 87 Chief.
It is still Renix, 4.0,  93 Aw4 T-case and high pinion Dana 30 (open), Spring over 8.8 with a grizzly locker. Rubicon express 7.5 long arm front lift.
Half the dirtbound catalog. Frame stiffeners.
 I received this truck as a rolling shell 4 years ago. Hoping to repaint it next year and I would love to know the paint code as well as where this thing was sold originally. It has changed quite a bit.
currently in Carson City Nevada.
*A6 Seats - Vinyl High Back Bucket
-YY
3LX
AGI
APA MONOTONE PAINT PACKAGE
BCQ Battery - Maintenance Free
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
DGW Transmission - 4-Spd. Automatic
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GFD SLIDING RR WINDOW
GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME
HAA AIR CONDITIONING
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JHA WINDSHIELD WIPERS - DELUXE
JJA CIGAR LIGHTER - FRT COMP
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAE EMISS CONTROL TESTING LABEL
PYN
QYN
RAB Radio - AM/FM
SBA POWER STEERING
SCE STRG WHL - EURO/SPORT TYPE
SUA TILT STEERING COLUMN
TBG SPARE TIRE - COMPACT
TBL TIRE CARRIER - INSIDE
WJN 15" ALUMINUM WHEELS
Build date 10/8/86
Body code JH61
Sold by STOCKTON JEEP-EAGLE, STOCKTON CA
18 hours ago, fiatslug87 said:
Paint: Briarwood Metallic
Pardon my ignorance but I’m searching around and briarwood metallic is only pulling up the wood paneled xj’s. I’m not finding anything that is the same dark brown metallic as mine
Welcome and you’ll have to type in the paint code. There’s also some sites that have AMC and Jeep paint codes. I recommend looking under AMC first then Jeep for the paint. The code should be PYN. If not look at your firewall tag for a two digit paint code.
  • 3 years later...
Before paint I had decided to utilize some dead space under the bed and make a little spare tire carrier, it’s made from two 36” trailor fenders with dimples for rigidity and cool points. It gets the 35” tire to sit 9.5” lower. I also modified the piece of bed that I cut out it be able to drop back in and make the bed normal if I didn’t want to carry the tire for whatever reason. The extra weight behind the rear axle made a noticeable difference off-road and in the snow.
