91Pioneer Posted July 12, 2023 Posted July 12, 2023 My 89 MJ had low voltage and it was dying so I kept it on the charger when I wasn't driving it. Today I put in a brand new AC Delco 335-1008 alternator that I got from RockAuto, it says it fits my truck. https://www.rockauto.com/en/moreinfo.php?pk=3468069&cc=1181674&pt=2412&jsn=1 Anywho I fired it up and the charge gauge went to the middle right away then climbed up to the red zone overcharging. I shut it down within like 15-20 seconds as I'm worried. What should I do now? The voltage regulator is built in in '89 but it's brand freaking new. Should I run it longer so it "learns" the voltage or what? I think I'll go back and let it idle for a minute or two and see if that helps calm it down. Grounds are good, battery connections are tight. No obvious any other issues. I didn't touch anything other than the battery terminals, the BAT terminal on the alternator and the wiring plug on it.
Ωhm Posted July 12, 2023 Posted July 12, 2023 Alternator needs counter voltage supplied by the battery. If battery is in poor condition or very poor condition, no counter voltage could put the alternator in a run-away situation. Put a voltmeter across the battery and check what your numbers are. Hopefully it’s the battery and not the alternator.
91Pioneer Posted July 12, 2023 Author Posted July 12, 2023 I ran it for about 3-4 mins and did a few voltage readings. Currently now after that with it off its 12.5V at the battery. When I started it for 2 mins at idle it was putting out 17.7 - 17.8V, with the high beams on it was 17.1V, with high beams and vent blower on high it was 15.1V. With DRLs on and vent on high was 16.9 - 17.0V. I shut it down then because the fuel pressure regulator was leaking pretty good. Maybe the fuel pump is going crazy and pushing way too much psi. I will put the battery charger on it overnight and try more tomorrow. I have things to do tonight.
acfortier Posted July 12, 2023 Posted July 12, 2023 Might be worth getting the battery tested at an auto parts store just to rule that out?
91Pioneer Posted July 12, 2023 Author Posted July 12, 2023 I have another battery I could try tomorrow out of my 91. My battery did take a beating this past week driving and charging when not driving but I did not drive very far.
91Pioneer Posted July 13, 2023 Author Posted July 13, 2023 OK well I did a couple of things, I set the battery charger on my 91 battery, not on my 89. SO... I swapped in the 91 battery which tested good, AND I put on a brand new positive battery cable because the terminal looked a little sketchy but was tight. And, it's still overcharging. My old battery was sitting at 3.8V so I don't know why that is, maybe it's bad or maybe the alternator damaged it? UPDATE: I called AC Delco tech hotline. They said the voltage regulator is bad and I need to warranty it. UGH he explained that's why my battery drained overnight. OK unfortunate but it is what it is.
91Pioneer Posted July 13, 2023 Author Posted July 13, 2023 7 minutes ago, fiatslug87 said: Send back the alternator and get a replacement. I edited my post. I contacted their tech support and I submitted for a replacement to RockAuto. The tech said if it's new and overcharging the 80% most likely cause is a failed internal voltage regulator.
