robfg67 Posted July 9, 2023 Share Posted July 9, 2023 I ran the MJ on a 50 mile highway trip yesterday on 88 degree heat, high humidity day and the temperature gauge increased slowly but hung around 230. It never got above that, but it was a little too close to the red for my liking. I've done my research and discovered that replacing the bottle with the 940 Volvo Turbo cap should help seal the system better, so I'll start there. Previous posts from many years ago say that the cap costs about $40. A Google search shows many caps for under $10. I found one on Amazon for $7.98; but want to be sure that I buy a good quality one. Any recommendations for where to get a good one? Link to comment Share on other sites More sharing options...
cruiser54 Posted July 9, 2023 Share Posted July 9, 2023 https://shop.advanceautoparts.com/p/carquest-premium-engine-coolant-reservoir-cap-10244/17110007-P Gotta ask though. How old is your radiator? Link to comment Share on other sites More sharing options...
robfg67 Posted July 9, 2023 Author Share Posted July 9, 2023 Looks original. Why do you ask? Link to comment Share on other sites More sharing options...
cruiser54 Posted July 9, 2023 Share Posted July 9, 2023 Might be a good time to replace your radiator with one from an open system. Those pressure bottles and caps are very prone to failure and your radiator is likely partially clogged anyway. Link to comment Share on other sites More sharing options...
robfg67 Posted July 9, 2023 Author Share Posted July 9, 2023 Would using the Prestone Flush Kit clear up most radiator clogs? Link to comment Share on other sites More sharing options...
cruiser54 Posted July 9, 2023 Share Posted July 9, 2023 Not likely. Cross flow radiators are the worst for holding crud inside. https://www.napaonline.com/en/p/NRCNR1193A Link to comment Share on other sites More sharing options...
robfg67 Posted July 9, 2023 Author Share Posted July 9, 2023 Cruiser54, This truck is a money trap!!! Is this a direct replacement or does it have a radiator cap? Link to comment Share on other sites More sharing options...
cruiser54 Posted July 9, 2023 Share Posted July 9, 2023 A replacement that has a radiator cap. Bolts right in. 35 years on the original radiator is hardly a money trap. I'm concerned that if you just replace the cap at this point, the bottle may fail. And I'm concerned about the radiator condition. Talk about spending money. Wait til your old radiator fails, or the coolant bottle, or the heater valve and almost all the coolant is gone instantly. Link to comment Share on other sites More sharing options...
acfortier Posted July 9, 2023 Share Posted July 9, 2023 Yeah, if you're pushing 230* I would probably start elsewhere than the cap. Replacing the radiator, if original, probably makes the most sense. Link to comment Share on other sites More sharing options...
robfg67 Posted July 9, 2023 Author Share Posted July 9, 2023 I'm not arguing. "Money trap" encompasses all the things that I've spent money on-not just the cooling system. I'll do the full conversion. Can anyone recommend a good DIY write-up? Link to comment Share on other sites More sharing options...
cruiser54 Posted July 10, 2023 Share Posted July 10, 2023 https://bleepinjeep.com/video/jeep-cherokee-closed-to-open-cooling-system-how-to-part-1-of-3/ Link to comment Share on other sites More sharing options...
Classy Comanche Posted July 10, 2023 Share Posted July 10, 2023 Or you can go thr route of my open cooling system. Bit more expensive...but can can still run the same radiator type. All the stuff I have is in my signature minus the radiator from napa Link to comment Share on other sites More sharing options...
cruiser54 Posted July 10, 2023 Share Posted July 10, 2023 But his radiator is old. Link to comment Share on other sites More sharing options...
