Hey guys really wanting to get this 2.8 out and get this thing on the road. I know everyone has their likes I’m getting lots of suggestions from friends but now really could use it from the experts who drive them. It’s an ‘86 2.8l 5 spd manual and best option (easiest and cheapest is the 3.4 mid nineties Camaro engine   When you have a moment I’d really appreciate all thoughts on what you have done or any better options. Sad thing is a swap is totally over my head I can do a lot but will have to hire out this job. This was a project my dad and I started before he passed away and now I have time to focus on it I’d really like to finish this thing. TIA and keep jeeping!!
The 3.4 being the closest swap is probably the way to go.
I did a similar swap in an 87 Toyota MR2, swapped in an engine and transmission from a 96 Japanese spec Corolla.  Mechanically it was very easy since it was the same basic engine, the more challenging part was integrating the electronics.  It was doable, people had done the exact swap before, just took a lot of patience and some research to get the things like tachometer, speedo, and electric fans working.
That’s what I have been seeing when I find an article   I just figured my two major concerns would be wiring needs and adapter for trans.  Thanks for responding
Actually the 2.8 runs really good it just has the power of the 2.8    Never was a strong engine. Even the 2.5 in my tj shows out over it.   It’s just a toy and wanting to do some kind of build with it
I really don’t have a budget figured for it yet. But a really good reminder that I need to do me a plan on all mods I’m wanting to do. I originally posted so maybe I would see some things I’d like to do. At this time not looking to build a setup around a motor and drivetrain but with a lift and bigger tires maybe up to 35s I’m needing the good stuff underneath to turn them. Like I said in my original post my dad bought this before he passed and he was a simple man. Getting it running down the road was his goal and we did that. But with me having four wheel drives since I’ve been driving and have been a crash repair tech for years. I am just wanting to create something different.  Anyway got the wife’s car in the shop about to paint it and then maybe I can get back on my project   Thanks for your responses.
the key is planning.  :L:  I've seen so many projects fizzle out because the owner just jumped in with only the end goal in his mind, not the steps needed to get there.  keep dreaming, keep reading, keep planning. :D
