garrett6410 Posted June 18, 2023 Share Posted June 18, 2023 Hear lately I've noticed my jeep has been getting extremely bad gas mileage such as about 8-11 mpg. Used to before I went up to 31s I was on 30s before it was getting about 17 18. It's got a new 02 NTK new sparks and newish spark plug wires replaced within 2 years any tips to help my gas mileage would be well appreciated and it also seems to have a miss I'm not sure on what cylinder or if it does at all it just seems to idle a little funny Link to comment Share on other sites More sharing options...
87MJTIM Posted June 18, 2023 Share Posted June 18, 2023 O2 sensor stuck in open loop? Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 18, 2023 Share Posted June 18, 2023 3 hours ago, 87MJTIM said: O2 sensor stuck in open loop? How do you test this... I am having the same issues. Link to comment Share on other sites More sharing options...
87MJTIM Posted June 18, 2023 Share Posted June 18, 2023 I can find Renix O2 testing. I think HO sensors work on diff scales. https://www.lunghd.com/Tech_Articles/Engine/Basic_Sensors_Diagnostics.htm Scroll down to the O2 sensor. Link to comment Share on other sites More sharing options...
garrett6410 Posted June 18, 2023 Author Share Posted June 18, 2023 2 hours ago, 87MJTIM said: I can find Renix O2 testing. I think HO sensors work on diff scales. https://www.lunghd.com/Tech_Articles/Engine/Basic_Sensors_Diagnostics.htm Scroll down to the O2 sensor. I'll have to look into that any other things you can think of Link to comment Share on other sites More sharing options...
cruiser54 Posted June 19, 2023 Share Posted June 19, 2023 The hose from the intake manifold to MAP sensor? Any vacuum leak there will tell the fuel injection system to add more fuel. Link to comment Share on other sites More sharing options...
Eagle Posted June 21, 2023 Share Posted June 21, 2023 Did you change the speedometer gear when you switched to larger tires? If not, the odometer is off and you have driven significantly father than what the dial shows. Which means your fuel mileage isn't as bad as you think. Link to comment Share on other sites More sharing options...
