speeding_infraction Posted June 15, 2023 Share Posted June 15, 2023 My truck has an uneven idle and it will die when warm if I don't keep my foot on the gas. I believe it's running too rich. Is this a symptom of a bad IAC, and how do I test this? Done some of cruiser's tips. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 15, 2023 Author Share Posted June 15, 2023 It's also worth noting that I have an HO intake manifold and throttle body Link to comment Share on other sites More sharing options...
MiNi Beast Posted June 15, 2023 Share Posted June 15, 2023 Check tps, iac, o2s... Or change cps and run it. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 15, 2023 Share Posted June 15, 2023 CPS will cause a no start, but not rough idle. Have you ever cleaned the throttle body and IAC? Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 15, 2023 Author Share Posted June 15, 2023 I just replaced the O2 sensor to fix something else, didn't seem to have any effect on idle. It has been doing this since I replaced the fuel pump. I should clarify, the idle isn't terribly rough, but it sounds kinda like it has a lumpy cam in it. I've poured half a can of seafoam through the throttle body, never cleaned it properly tho. Some times when it's warm I have to give it throttle to open up the throttle body and get it some air. Link to comment Share on other sites More sharing options...
Rick Lewis Posted June 16, 2023 Share Posted June 16, 2023 I am also having this prob with my 88 Jeep. I don't think it's the TPS again. I replaced the o2 Bosch 12009 yesterday and it ran great last night and to work today. Coming home today I stopped once for 15min and then it ran like crap again. Won't idle. I have to keep wrapping on the gas in neutral until the rpms are up and good then put it in drive to make it home. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 16, 2023 Share Posted June 16, 2023 Have you ever visited my website and completed Tips 1 through 5? Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 16, 2023 Author Share Posted June 16, 2023 Yes I have. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 16, 2023 Author Share Posted June 16, 2023 What should I clean the tb/IAC out with? Brake clean or something else? Link to comment Share on other sites More sharing options...
cruiser54 Posted June 16, 2023 Share Posted June 16, 2023 Or carb cleaner Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 19, 2023 Share Posted June 19, 2023 No one has mentioned manifold bolts yet. Have you checked if they are tight? Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 19, 2023 Author Share Posted June 19, 2023 I will check those, never checked em before. I do know it has an exhaust leak, but it sounds like it's coming from the back of the truck Link to comment Share on other sites More sharing options...
cruiser54 Posted June 19, 2023 Share Posted June 19, 2023 INTAKE manifold bolts. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 19, 2023 Author Share Posted June 19, 2023 15 minutes ago, cruiser54 said: INTAKE manifold bolts. Should I check exhaust manifold bolts as well just for kicks? Link to comment Share on other sites More sharing options...
cruiser54 Posted June 19, 2023 Share Posted June 19, 2023 sure. Actually the lower bolts hold both intake and exhaust manifolds. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 22, 2023 Author Share Posted June 22, 2023 How on earth do I reach those bottom bolts.... I can't even see them 🤦🏼♂️ All the bolts that I could reach are tight Link to comment Share on other sites More sharing options...
cruiser54 Posted June 22, 2023 Share Posted June 22, 2023 Remove the air cleaner box and use extensions. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 22, 2023 Author Share Posted June 22, 2023 I was able to reach all the bolts/nuts and they are all tight. When I unplug the IAC it's makes a loud hissing noise, that gradually disappears when I plug it in again. Does this mean that it is working? Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 22, 2023 Author Share Posted June 22, 2023 Ok I just started it up for the first time this morning and it is now hissing full time, plugged in or not Link to comment Share on other sites More sharing options...
cruiser54 Posted June 22, 2023 Share Posted June 22, 2023 WHAT is hissing? Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 22, 2023 Author Share Posted June 22, 2023 The IAC I believe. Here's a video if that would be helpful. Could also be a vacuum leak now that I think about it... https://photos.app.goo.gl/1reW2e9fCxhQSWDs5 Link to comment Share on other sites More sharing options...
cruiser54 Posted June 22, 2023 Share Posted June 22, 2023 REplace the o-ring on it. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 22, 2023 Author Share Posted June 22, 2023 I pulled the IAC valve and the o ring looked in good condition. The threaded pintle was just sitting inside the valve body. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 22, 2023 Author Share Posted June 22, 2023 Link to comment Share on other sites More sharing options...
cruiser54 Posted June 22, 2023 Share Posted June 22, 2023 You need a new one Link to comment Share on other sites More sharing options...
