Rollbar drawing
So I've been hesitate about posting this, as FULL DISCLOSURE: I AM NOT A DRAFTSMAN. Not sure how accurate this drawing is. Drawing is at the bottom.
With that being said, someone was kind enough to let me measure their SWB Factory Rollbar. If anyone is adventurous enough to have a muffler shop bend one, it will be about the same quality and thickness as the originals. Better yet if someone has access to a mandrel tube bender and wants to make ones that would actually protect you in a rollover. I bet you could sell a few. :brows:
ComancheRollbar.pdf
  • 4 months later...
On 6/6/2023 at 2:36 PM, Salvagedcircuit said:
Very cool! At this point, I should just try and make one for my long bed as I have a better chance of winning the lotto than finding one in any affordable manner.
Let me know how the measurements worked out if you do.
  • 1 month later...
  • 7 months later...
Do you have any info on the mounting brackets.  I located an aftermarket one but it doesn't have the brackets.  I'm searching for pictures or info on how they are actually mounted, especially the front part
The fronts are 5 1/8”x4 1/2” and bolt in front of the drain plugs and brackets (G&F in the diagram) under the bed are required for installation. The rears are 7 1/2”x5 1/2” and mount to the front of the wheel well and also have a backing plate (E in the diagram) underneath. All have rubber gaskets between them and the bed (D in the diagram).
Fronts:
Rears:
Thanks for the pictures and measurements.  They are a huge help.  At least now I know where and how to start.I have a copy of that drawing in my manual.  Do you know the measurements for the brackets under the bed?.  I think I'm gonna have to fabricate something as I know those brackets are next to impossible to find.  I guess I could always do the cardboard aid and design method.
