HOrnbrod Posted December 22, 2007 Share Posted December 22, 2007 I used these lights below. They are made by Hella (p/n 161949117) and are the same as those the 1985-1992 VW Jetta 2's and Audis use. Since I wanted them in the same location as the Export XJs, I selected these because they were similar in appearance to the Export XJ side repeaters and the size was nearly a perfect match. They only require two round holes (7/8" and 5/16") to mount. I used a chassis punch for the large hole, then drilled the smaller hole. I made up two 4' 2-wire harnesses and ran the wires out through existing holes in the inner fender and out the large hole in the outer fender. I popped the fender liner loose at the top to fish the wires through. Wires connected to the bulb holder using spade connectors through a rubber boot. Do a smoke test first, then pop the lamp into the holes. It uses a plastic pressure arm to latch in. To change bulbs you slip a stout feeler gauge under the lamp and push in to release the assembly. Then run the wires along the inner fender in the engine compartment out through the front corner light hole, and parallel the connections. The side markers act as running lights when the parking or headlights are on, and of course flash as turn signal repeaters. Link to comment Share on other sites More sharing options...
jtdesigns Posted December 23, 2007 Share Posted December 23, 2007 Looking good!! :thumbsup: Do the corner lights flash with the turn signals? I don't think mine flash.. I may be wrong though. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 23, 2007 Author Share Posted December 23, 2007 Looking good!! :thumbsup: Do the corner lights flash with the turn signals? I don't think mine flash.. I may be wrong though. Yes, the corners alternate flashing with the parking lights. I think this started with the 1991 models. There is a writeup somewhere on how to do this; I'll try to find it. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 23, 2007 Author Share Posted December 23, 2007 Looking good!! :thumbsup: Do the corner lights flash with the turn signals? I don't think mine flash.. I may be wrong though. Yes, the corners alternate flashing with the parking lights. I think this started with the 1991 models. There is a writeup somewhere on how to do this; I'll try to find it. The writeup for this is in the Electrical section of here: http://www.madxj.com/ Link to comment Share on other sites More sharing options...
jtdesigns Posted December 23, 2007 Share Posted December 23, 2007 Nice lil project I need to do. Thanks! :cheers: Link to comment Share on other sites More sharing options...
Whiteshark Posted December 23, 2007 Share Posted December 23, 2007 hey man i know its kind of off topic but your jeep ravine wheels are the 15s or 16s? Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 23, 2007 Author Share Posted December 23, 2007 hey man i know its kind of off topic but your jeep ravine wheels are the 15s or 16s? No problem. I steal threads all the time. :eek: :cheers: 15" Ravines w. 31s. Link to comment Share on other sites More sharing options...
jtdesigns Posted December 23, 2007 Share Posted December 23, 2007 Hornbrod I think this should be in the DIY part http://www.comancheclub.com/forums/viewforum.php?f=9 Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 23, 2007 Author Share Posted December 23, 2007 Yeah, it should be - my bad. Forgot about the DIY section. :nuts: Maybe the Pete-man can fix it? Link to comment Share on other sites More sharing options...
Pete M Posted August 6, 2008 Share Posted August 6, 2008 Only if Pete notices it. :roll: Link to comment Share on other sites More sharing options...
MJ'87 Posted August 9, 2008 Share Posted August 9, 2008 ha ha. i must have seen it 50 times before, but hornbrod, your bug almost just got me :teehee: Link to comment Share on other sites More sharing options...
