OME shocks
I recently installed a set of Rusty’s 3.5” rear leafs on my 89 LWB. I have 4” coils up front.  I found a BNIB set of OME 60052L front shocks which will work for the front. I found these OME 60053L rear shocks which look like they’ll work for the rear. Anyone have any experience with these?
OME shocks are excellent items, assuming you can find ones that fit the MJ correctly.  (The fronts are the same as an XJ, so that won't be a problem.  The backs, which are unique to the MJ, are the challenge.)
On 5/21/2023 at 9:12 AM, cruiser54 said:
They're the correct length for your lift?
I am hoping to take measurements today. I was only asking if anyone has run these. From what I recall reading about the OME rear shocks on an MJ, there were ZJ shocks that would work but it depended on lift height. So when I saw these on Quadatec figured I’d ask on the forum
