Htchevyii Posted April 24, 2023 Share Posted April 24, 2023 I know that radiators are a common subject of confusion so here's my experience. I'm currently running a Performance Radiator single row 1-1/2" thick radiator in the MJ and my "new" XJ. They cost about $130 with free shipping. They do have the provision for the fan sensor and a thicker core than the Spectra Premium. I did try a Cold Case all aluminum unit. Unfortunately, even with new transmission and engine mounts installed at the same time, there just wasn't sufficient clearance and the first time that I took it off road the fan clutch destroyed the radiator. Cold Case blamed the aftermarket fan clutch. Nevermind that I've had the truck for 30 years and 4 radiators and never had an issue. Anyway, I switched to the Performance Radiator 3 years ago and it's been working great, also no fan contact even with the same fan clutch. Hope this helps someone. The bottom two pics are the Cold Case. Link to comment Share on other sites More sharing options...
75sv1 Posted April 24, 2023 Share Posted April 24, 2023 I was warned by Dirk at DPG Offroad about an aftermarket clutch fan and a 2 or 3 row radiator. Yes, that 1/2 inch or so makes a difference. Yes, Deth Wobble and stock motor mounts did not help the situation. I am running electric fans now. Link to comment Share on other sites More sharing options...
BizarroStormy Posted April 24, 2023 Share Posted April 24, 2023 I am using this super cheap three row all aluminum radiator off amazon. https://www.amazon.com/gp/product/B00JVC0SYQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Seems to work as good as the copper/brass one it replaced. Only downside I have experienced with it is the tiny mounting screws on the top are also aluminum so super easy to break. Fit with my stock fan. Link to comment Share on other sites More sharing options...
Classy Comanche Posted April 24, 2023 Share Posted April 24, 2023 Whatever you do do not order the all aluminum off rockauto. The very bottom one is a waste of money and I'm about $500-$600 deep in them and my return date is past. I got one from Napa. Works like a charm. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 24, 2023 Share Posted April 24, 2023 I had the mishimoto and didn’t have an fitment issues even with my HD clutch but I’ve heard it not working for some. Although your fan clutch looks different than mine did. Mine didn’t have those “tabs” sticking out. I’ve come to believe that fluid capacity is key with these radiators. I’d be curious to see a fluid capacity comparison on the various models. Link to comment Share on other sites More sharing options...
Htchevyii Posted April 24, 2023 Author Share Posted April 24, 2023 7 hours ago, Classy Comanche said: Whatever you do do not order the all aluminum off rockauto. The very bottom one is a waste of money and I'm about $500-$600 deep in them and my return date is past. I got one from Napa. Works like a charm. There is a 27 or so page thread on one of the XJ forums about radiators. My takeaway was that almost all of the welded aluminum units would eventually crack if used off road, especially the cheaper ones. I don't really like the plastic tanks, but they seem to handle flexing and vibration better than some of the welded aluminum units. Link to comment Share on other sites More sharing options...
Lector Manche Posted May 24, 2023 Share Posted May 24, 2023 On 4/24/2023 at 1:27 PM, Htchevyii said: There is a 27 or so page thread on one of the XJ forums about radiators. My takeaway was that almost all of the welded aluminum units would eventually crack if used off road, especially the cheaper ones. I don't really like the plastic tanks, but they seem to handle flexing and vibration better than some of the welded aluminum units. Do you have link to this post? Link to comment Share on other sites More sharing options...
Htchevyii Posted May 24, 2023 Author Share Posted May 24, 2023 Here you go: https://www.naxja.org/forum/showthread.php?t=1150722&page=16 Link to comment Share on other sites More sharing options...
