I have a 1988 MJ that according to VIN began life as a 2.5L.
It's been swapped with a 1995 4.0L from an XJ.
I need help finding the correct Air Conditioning kit to put into this vehicle.
Any ideas?
You need to get one from late 94 built xj as that’s when they went r134 from the factory. 95/ 96 xj same hvac components if you’re looking to match your trucks engine vintage. Otherwise you can get 91-96 xj hvac to bolt in. Just pick a year.
some of the parts you'll want to buy new (you'll find them individually, not as a kit), but most you'll be grabbing from the junkyard (the hvac box and hoses for example). :L:
