Does anyone have part numbers for all 4 a/c hoses? Rockauto only has the suction/discharge hoses and I need the other two as well
56002731 ->4773305
56002732->4773306
I only see three hoses in the catalog per your vehicle. You’re not referring to the small one off the dryer are you?
2 hours ago, eaglescout526 said:
56002684
56002731 ->4773305
56002732->4773306
Think so. Expansion to condenser, condenser to dryer, dryer to compressor, compressor to expansion. Might have the wrong order but there's definitely four hoses in the engine bay
It's been several years, but when I repaired the AC on my 91, there was a hose that wasn't available.  I ended up sourcing a used one from a junkyard XJ.  I think it was the small one on the dryer.
When I installed a whole system I used some 91+ lines from jeepair. Parts list for everything and maybe some info on this post ( click arrow)
Actually stumbled across your post shortly after posting. Should be blowing cold by end of week 👌🏼
