CB Radio Mounting Locations?
Those mount locations look like they are either in the heater box or close to it. How do your CBs function in there?
I am also trying to decide where to put mine, seems like under the dash near the TCU bracket would be a good fit.
I never had a problem with mine in there, the heat worked as it should, and it never overheated or anything. I only removed mine because I didn’t use it enough and I think it’s a cleaner look without it
