Quicky
Joe Dirt
this is more complicated than you think.  the tire will mount on it, but that rim will push the tire out quite a bit and make contact with the flares.  how much lift do you have?  what's the backspacing on those rims?
Not just this, the tire will be a gigantic pain to bead, all being anything can be done with ether and a dream, but also if your planning to 4 wheel it at all airing down is just gonna allow the tires to de-bead very easily. 7” and 8” wheels are perfect for 31x10.5
8’s give them a more squared off look, where 7’s crown a bit
