TheDirtyJeep401 Posted January 27, 2023 Share Posted January 27, 2023 86 with a A904 transmission. According to the service manual, it says Dexron II. I know that they changed to Dexron III saying it is a replacement for II. I’ve found 2 types of III, Dexron IIIH and IIIE. Is E just an extra additive for corrosion resistance, and are interchangeable? Just wanting to make sure, can’t find much on the old A904s. Link to comment Share on other sites More sharing options...
Eagle Posted January 28, 2023 Share Posted January 28, 2023 I thought the 904 used ATF, not Dexron. Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted January 28, 2023 Author Share Posted January 28, 2023 That’s what I thought too. Went out and grabbed the owners manual for it just to check. I figured it was the same as 727 and 904s in earlier AMCs Link to comment Share on other sites More sharing options...
cruiser54 Posted January 28, 2023 Share Posted January 28, 2023 Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted January 28, 2023 Author Share Posted January 28, 2023 Awesome! Just wanted to make sure. Thank you guys! Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted June 26, 2023 Author Share Posted June 26, 2023 So after I noticed that the fluid level was a little low I topped it off with Dexron. Here lately when starting the truck up, usually when it’s cold, it doesn’t want to fully engage in reverse or it shakes trying to back up. Foward gears are just fine. Let it warm up and it seems to be going into reverse just fine. Fluid level is where it should be and still does it. I plan on changing the fluid and filter. Is there anything else I should do and or look for? Adjustments of any kind? Link to comment Share on other sites More sharing options...
The86manche Posted June 26, 2023 Share Posted June 26, 2023 If you are comfortable doing it there are bands you can adjust Link to comment Share on other sites More sharing options...
