Jamieb Posted November 15, 2022 Share Posted November 15, 2022 I have a question and I'm hoping someone has a answer I'm reassembling my 1986 comanche that has a 2.1L renault diesel engine hopefully the engine all when together ok But I'm having a issue with timing marks the cam and injection pump are quite easy BUT I cannot find any marking to line up the crankshaft (marks on the crank but nothing to line up with on the block) I have looked endlessly online but I can't find anything Does anyone have a picture or something that I can work with Thanks Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 15, 2022 Share Posted November 15, 2022 And you’re not going to find anything either. I recommend you get the AMC 2.1L dealer service book. Funny enough I never thought I’d have to pull mine out of my collection to reference. Now the crank sprocket does not have any marks what so ever. Now there’s a tool thanks to Renault being typical “clean euro design” style unlike the Americans with a main crank pulley with marks, you need a special tool to find top dead center. Link to comment Share on other sites More sharing options...
Pete M Posted November 15, 2022 Share Posted November 15, 2022 1 minute ago, eaglescout526 said: you need a special tool to find top dead center. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 15, 2022 Share Posted November 15, 2022 24 minutes ago, Pete M said: Exactly….I was and wasn’t shocked to see a special tool to find TDC. But like the OP said, everything is marked. But he may not need a real special tool, just a simple rod of the right diameter to fit into the holes of the crank shaft from what I read about the timing belt. Link to comment Share on other sites More sharing options...
neohic Posted November 15, 2022 Share Posted November 15, 2022 Pictures are dead, but Rob used a 5/16” drill bit. Link to comment Share on other sites More sharing options...
Jamieb Posted November 15, 2022 Author Share Posted November 15, 2022 Thanks for the info Very Much appreciated everyone Link to comment Share on other sites More sharing options...
