pizzaman09 Posted June 8, 2023 Share Posted June 8, 2023 You were not kidding about the low quality of the throughout bearing. The one I got with the kit is 0.066 inches eccentric. That would make a racket and probably wear out the clutch springs due to the wobble. I shall be purchasing a higher quality one. Link to comment Share on other sites More sharing options...
Htchevyii Posted June 8, 2023 Author Share Posted June 8, 2023 I didn't think it was worth the risk. Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 10, 2023 Share Posted June 10, 2023 I will say mine did come with the seal in the front housing. Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 15, 2023 Share Posted June 15, 2023 On 6/7/2023 at 8:39 PM, pizzaman09 said: You were not kidding about the low quality of the throughout bearing. The one I got with the kit is 0.066 inches eccentric. That would make a racket and probably wear out the clutch springs due to the wobble. I shall be purchasing a higher quality one. So, I ordered a National bearing throw out bearing, and it looked just like the one above. So after some research, apparently this is what it's supposed to look like, it actually is spherically mounted and will center itself once it engages with the clutch. In any case, I'm happy to have a national brand bearing and will utilize it. Link to comment Share on other sites More sharing options...
rokinn Posted April 21, 2024 Share Posted April 21, 2024 On 11/11/2022 at 7:54 PM, Htchevyii said: Update, the new parts are all installed and working well. I'll post a link to the YouTube video that I made that covers the external slave swap using the Advance Adapters kit and their new AX15 as well as the transfer case refresh. Hi guys, on our last trip the LUK internal slave cylinder completely gave out with just 15000 miles in it. We drove almost 500 miles home with no clutch. This prompted a conversion to the external slave setup. I decided to just buy the brand new AX15 that Advance sells at the same time, since my current trans has close to 300k on it. Here's a few things I learned that might help someone. -The kit comes with almost everything you need, but no front input seal -The instructions suck, all I ask is for one decent photo or illustration of the clutch fork setup. - I didn't trust the included non branded throw out bearing, so I purchased a National. It looks of higher quality and seemed to spin smoother. -I redrilled the rear housing to the XJ,MJ pattern. Someone posted a file for a 3D printed drill guide and I had my friend make me one. It worked awesome. I can't remember where I got the file from now. I believe the OE holes are 11MM. I used the next size smaller standard bit and it still slid right together. -AA says to use only a particular Mopar 10w30 or Redline MTL. My dealer didn't have the 10W30, so I ordered Redline from Summit Racing. Actually, I ordered the transmission and slave kit from Summit as well. -I'm assuming that I voided the warranty by drilling the new holes. Novak will send you one pre drilled, but it was a few hundred bucks more. There are also clocking rings available. - I found people (Motor trend) didn't receive or lost the fork retainer clip on the pivot and had to pull the trans. - I am still trying to figure out if it matters which direction the clutch fork is mounted? You can't tell in their picture and their tech section on their website is down. Conflicting info everywhere. I did find a diagram on Repair link, do I am going with that unless someone knows better and soon . Here is a link to the drill jig file if you have or know someone who can print it for you. https://www.thingiverse.com/thing:5665772 Hi, nice write up. I'm looking at this job myself now. I'm sourcing all of the parts individually. Was the braided line that comes with the kit the 42" version and was it a good fit? I haven't pulled the trigger on most of the parts just yet. I have sourced a 48" line, haven't found a 42" one yet. If the 42" was pretty optimal I will keep looking. Ride height is stock. Thanks. I enjoy your travel videos also. Link to comment Share on other sites More sharing options...
rokinn Posted April 21, 2024 Share Posted April 21, 2024 On 11/12/2022 at 7:11 PM, ghetdjc320 said: Parts: https://www.ebay.com/itm/283935073099?epid=13032515528&hash=item421bd9634b:g:-cEAAOSwd3Ne~h6v&amdata=enc%3AAQAHAAAA4IdVAEHl%2F0ynxsisSWaVk9bYD3xVq3C%2BcdWkcbXdgQYOhadaa%2BynGbI3QFT24cW7PsaOhOinOK8hpMlM%2BPa1XpG8TC5U1lh6M8%2BP7sV5PhDNLRtED7C0ZMxyteuQa%2BM7UGWEf3mM6wBGr%2FG9vOkG11VZIacR5jxyZMJwtD30pV7kDI5dgkQT0xkC3W8hbY1iDwLgaHLS3kwxzQ1mDGBXviK1EkGMaVge8y%2BnwlofzHirAk%2Fvv7PgLjf0Rb7Abae%2BEzFxEJZxGm%2F%2BEN5AtZdUGuocugjCximU2tYMZMhR4M6K|tkp%3ABFBM7q-r6I1h https://www.ebay.com/itm/284936996104?epid=5018356666&hash=item4257918508:g:wdEAAOSw5cNYgVBr&amdata=enc%3AAQAHAAAAoKjtOy%2BNoT7efsIOM2TJTRdR%2FCMPd6whb8UoEY24TnamTX%2FZiAf5ktigQB6lUIvCi2BMT64XZShkRjgyoDsjI0YcLv59BV5E9Pp%2FraMcjCsod8HwETTGdP3GXrid6%2FaEOYR9lHDu4zepZYP1gksW0ZzHa6Ub1bWqCs2pq7HFq5rzPn%2B0hZZPjApIIDytJy%2F1RthSd9XN%2BdGYAn8U%2FbBSpMA%3D|tkp%3ABk9SR5bjs-iNYQ The metal slave with bleeder I got is from quickdraw but I know they are sourcing that elsewhere. I’d ask them where since it’s not the luk unit I was thinking Hi, I'm working on my parts list for the conversion to external slave. Is this the slave you were mentioning? https://quickdrawbrand.com/slave-cylinder---.75-bore-external-w/-3an-fitting/#product-reviews Also, I'm thinking about a disc/pressure plate upgrade. Do you think it's worth the extra expense or is a Luk plenty adequate? https://www.amazon.com/dp/B000CIUU5A/?coliid=I2G41DNIO024ZW&colid=3H4LKU0FVHV2X&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it Thanks, I always appreciate your knowledge about most everything you comment on. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 21, 2024 Share Posted April 21, 2024 1 hour ago, rokinn said: Hi, I'm working on my parts list for the conversion to external slave. Is this the slave you were mentioning? https://quickdrawbrand.com/slave-cylinder---.75-bore-external-w/-3an-fitting/#product-reviews Also, I'm thinking about a disc/pressure plate upgrade. Do you think it's worth the extra expense or is a Luk plenty adequate? https://www.amazon.com/dp/B000CIUU5A/?coliid=I2G41DNIO024ZW&colid=3H4LKU0FVHV2X&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it Thanks, I always appreciate your knowledge about most everything you comment on. Yep that’s the one. For the most part, the luk rep-set is a good option. Not too grabby either Link to comment Share on other sites More sharing options...
Htchevyii Posted April 21, 2024 Author Share Posted April 21, 2024 2 hours ago, rokinn said: Hi, nice write up. I'm looking at this job myself now. I'm sourcing all of the parts individually. Was the braided line that comes with the kit the 42" version and was it a good fit? I haven't pulled the trigger on most of the parts just yet. I have sourced a 48" line, haven't found a 42" one yet. If the 42" was pretty optimal I will keep looking. Ride height is stock. Thanks. I enjoy your travel videos also. The included line was plenty long. Good luck with your swap! Link to comment Share on other sites More sharing options...
rokinn Posted May 5, 2024 Share Posted May 5, 2024 On 4/21/2024 at 2:44 PM, ghetdjc320 said: Yep that’s the one. For the most part, the luk rep-set is a good option. Not too grabby either Thanks for that. Got the tranny out, half way there. Link to comment Share on other sites More sharing options...
rokinn Posted May 5, 2024 Share Posted May 5, 2024 On 4/21/2024 at 3:03 PM, Htchevyii said: The included line was plenty long. Good luck with your swap! Thanks, I'm half way there, transmission is out. Link to comment Share on other sites More sharing options...
