ghetdjc320 Posted November 11, 2022 Share Posted November 11, 2022 I’ve come across a few of these XJ splash guards from the 97+. Any thoughts on fitment for an MJ? I’m assuming a slightly different flare profile. Link to comment Share on other sites More sharing options...
Airborne Janitor Posted November 11, 2022 Share Posted November 11, 2022 The bolt holes on the front fenders/flares should be the same for all MJ & XJ years, so they should bolt up. Of course the 97+ flares are shaped a little different, but I think they would work with the pre97 flares. I was thinking of the fender holes, not the holes for the actual mud flap. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted November 11, 2022 Share Posted November 11, 2022 I have some splash guards from a 97+, I can hold them up to my Comanche to show you what they look like. Supposed to get heavy rains all day today but I can do it for you tomorrow if nobody else responds Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 11, 2022 Author Share Posted November 11, 2022 5 hours ago, Strokermjcomanche said: I have some splash guards from a 97+, I can hold them up to my Comanche to show you what they look like. Supposed to get heavy rains all day today but I can do it for you tomorrow if nobody else responds Sounds good, thanks Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted November 13, 2022 Share Posted November 13, 2022 On 11/11/2022 at 9:44 AM, ghetdjc320 said: Sounds good, thanks Doesn’t look good at all in my opinion.Doesn’t look good at all in my opinion. Rear is exactly the same. I believe husky and several other brands made splash guards for the 84-96 flares. If you can find those I believe that would be a better option. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 13, 2022 Author Share Posted November 13, 2022 Can’t tell for sure but doesn’t it have a gap from the flare near the bottom or does it contour to the flare all the way down? Husky has some universal ones that I could trim to the right shape I suppose. I like the look of the old style XJ rears on the rear of the MJ more than the stock MJ rears. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted November 13, 2022 Share Posted November 13, 2022 1 hour ago, ghetdjc320 said: Can’t tell for sure but doesn’t it have a gap from the flare near the bottom or does it contour to the flare all the way down? Husky has some universal ones that I could trim to the right shape I suppose. I like the look of the old style XJ rears on the rear of the MJ more than the stock MJ rears. It does not follow the contour of the flare all the way down. There was about a three-quarter inch gap at one point in the middle of the radius of the flare. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 13, 2022 Author Share Posted November 13, 2022 11 minutes ago, Strokermjcomanche said: It does not follow the contour of the flare all the way down. There was about a three-quarter inch gap at one point in the middle of the radius of the flare. Good to know, thanks for taking the time to moch those up Link to comment Share on other sites More sharing options...
Minuit Posted November 13, 2022 Share Posted November 13, 2022 1 hour ago, ghetdjc320 said: Can’t tell for sure but doesn’t it have a gap from the flare near the bottom or does it contour to the flare all the way down? Husky has some universal ones that I could trim to the right shape I suppose. I like the look of the old style XJ rears on the rear of the MJ more than the stock MJ rears. Old style fronts on the rear of the MJ are the way to go IMO: Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 13, 2022 Author Share Posted November 13, 2022 19 minutes ago, Minuit said: Old style fronts on the rear of the MJ are the way to go IMO: Those looks good also. I had that setup on my last MJ. Link to comment Share on other sites More sharing options...
