KANTANKRUS Posted October 27, 2022 Share Posted October 27, 2022 1987 MJ, I discovered this bracket dangling from the push rod on my Clutch Master Cylinder, (no wonder why my clutch pedal went clear to my underside of my dashboard. This bracket is 1/4" plate (just how the hell did that happen?) So, my question is... do I need to remove the entire pedal assembly, in order to 'bench weld' that S shaped bracket back onto the pedal assembly, or can I simply remove the bolt, circled in red? And if I remove that bolt, will there be an internal spring withing that horizontal cylinder that the pedal rotate on? Please advise... thanks in advance! Link to comment Share on other sites More sharing options...
KANTANKRUS Posted October 27, 2022 Author Share Posted October 27, 2022 This is the S shaped bracket, that I am referring to. Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 27, 2022 Share Posted October 27, 2022 Yes just remove bolt. Link to comment Share on other sites More sharing options...
KANTANKRUS Posted October 28, 2022 Author Share Posted October 28, 2022 20 hours ago, MiNi Beast said: Yes just remove bolt. Thank you! Link to comment Share on other sites More sharing options...
KANTANKRUS Posted October 29, 2022 Author Share Posted October 29, 2022 Question, does that same bolt have a nut on the other side? Link to comment Share on other sites More sharing options...
Pete M Posted October 30, 2022 Share Posted October 30, 2022 yes Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 30, 2022 Share Posted October 30, 2022 Link to comment Share on other sites More sharing options...
KANTANKRUS Posted October 30, 2022 Author Share Posted October 30, 2022 1 hour ago, Pete M said: yes Yikes! Link to comment Share on other sites More sharing options...
cruiser54 Posted October 30, 2022 Share Posted October 30, 2022 Link to comment Share on other sites More sharing options...
KANTANKRUS Posted March 9, 2023 Author Share Posted March 9, 2023 On 10/30/2022 at 8:46 AM, cruiser54 said: Good gravy, I just saw this... sorry for the YUGE delay. My life has been one big roller coaster since 30 October 2022, sadly. So that depiction shows 'the brake pedal' Does that rod also pass through the 'clutch pedal assembly'? Please advise. TIA! Link to comment Share on other sites More sharing options...
KANTANKRUS Posted April 9, 2023 Author Share Posted April 9, 2023 On 3/8/2023 at 9:55 PM, TurtleHare said: Good gravy, I just saw this... sorry for the YUGE delay. My life has been one big roller coaster since 30 October 2022, sadly. So that depiction shows 'the brake pedal' Does that rod also pass through the 'clutch pedal assembly'? Please advise. TIA! Once again, does that depiction show 'the brake pedal assembly as well as the clutch pedal assembly? Please advise! Link to comment Share on other sites More sharing options...
