Windshield trim removal
The trim is just held in place with some plastic clips (that are some times in bedded in the sealant) just pry off the trim from the glass side/edge, and it will pop right off, start on the top piece, down the sides, across the bottom, and done ;)
was anyone able to get the clips back on? I just ditched them and used silicone (on the bottom one anyways...)
As long as they aren't broken, it'll all just snap back together. Normally they break when you pull the trim though, they just get too brittle after years of exposure.
