JYau Posted July 14, 2022 Share Posted July 14, 2022 I need a replacement Intermittent Wiper Module. I'm not sure which years are compatible with others but I need one for an 88 Comanche. The going rate on is eBay is about $50-$60 and most of them don't specify if they are even working or not. Link to comment Share on other sites More sharing options...
Pete M Posted July 14, 2022 Share Posted July 14, 2022 do any of the sellers offer free returns? I'd bet some do. Link to comment Share on other sites More sharing options...
88mjsally Posted July 14, 2022 Share Posted July 14, 2022 I have quite a few but none have been tested Link to comment Share on other sites More sharing options...
scguy Posted July 15, 2022 Share Posted July 15, 2022 Are you handy with a soldering iron? https://youtu.be/fnzBP-RfuLA Link to comment Share on other sites More sharing options...
JYau Posted July 18, 2022 Author Share Posted July 18, 2022 I'm very handy with a soldering iron and electronics, I actually tried to repair the one I have now. But I found out that it was a much older style module with a mechanical relay that was not in a potted package. The relay had an exposed bobbin where the magnetic wire got corroded and failed. From the video you sent and what I found online, there is a newer design with a different board layout and a potted/packaged relay. That one is much more realistic to repair. To repair the module I have now would require me to manually rewire the bobbin with what looks like a thousand turns of 36 AWG magnetic wire. Link to comment Share on other sites More sharing options...
Pete M Posted July 18, 2022 Share Posted July 18, 2022 is there a part number distinguishing the 2 styles? Link to comment Share on other sites More sharing options...
JYau Posted July 18, 2022 Author Share Posted July 18, 2022 I'm not sure on differences within the part numbers, but here is the part number for the one with the older style relay: SF8956000428 Link to comment Share on other sites More sharing options...
JYau Posted July 19, 2022 Author Share Posted July 19, 2022 Wiper Module had been found and purchased. Link to comment Share on other sites More sharing options...
