86 Mj engine swap
13 hours ago, eaglescout526 said:
It should bolt up with no issues at all. Butttttt you might run into issues with the 86 being an auto and the 2.5L being an HO era engine. Are you swapping the engine and engine management over or are you converting it to Renix?
Thx for the reply... I would swap it all if I did it...just wanted to be sure before I make a decision
