Cluster Speedo Swap
I still have my trucks original cluster, its just a plain 89 base model cluster with dummy lights and no tach. If I get the same style cluster from an 87 that has a tach and gauges, can I just unscrew the original speedo and swap it out with no problems? The only reason I wanna do this is for the odometer.
the link in my signature has a writeup on it. :D
It's illegal to falsify your odo for the purpose of tricking a future buyer to think the truck has less miles than it really has.
it's not illegal to make your truck correct. :L:
I've done the same thing to my jump as well as adjusting the odometer. It is doable and from what I remember there is a small C-clip you have to remove to pull the number wheels out. Careful with that as you don't want to lose that clip.
