JWheeler331 Posted July 5, 2022 Share Posted July 5, 2022 Here recently my Part Time light has started coming on. Usually when I take my foot off of the gas coming to a stop. Would this appear to be a vaccume issue? Link to comment Share on other sites More sharing options...
Eagle Posted July 6, 2022 Share Posted July 6, 2022 On 7/5/2022 at 2:08 PM, JWheeler331 said: Here recently my Part Time light has started coming on. Usually when I take my foot off of the gas coming to a stop. Would this appear to be a vaccume issue? Definitely. You have the central axle disconnect on the front axle. That's operated by vacuum. There's a multi-tube vacuum harness that operates that, and it happens to be located right under the oil filter. Over time, drips from oil filter changes soften and destroy the connectors, resulting in vacuum leaks. Link to comment Share on other sites More sharing options...
JWheeler331 Posted July 8, 2022 Author Share Posted July 8, 2022 On 7/6/2022 at 5:47 PM, Eagle said: Definitely. You have the central axle disconnect on the front axle. That's operated by vacuum. There's a multi-tube vacuum harness that operates that, and it happens to be located right under the oil filter. Over time, drips from oil filter changes soften and destroy the connectors, resulting in vacuum leaks. Thank you. I replaced all of the upper vaccum hoses. I guess next up will be the lower ones. Link to comment Share on other sites More sharing options...
Pete M Posted July 9, 2022 Share Posted July 9, 2022 another option is to shift the cab permanently and plug the vacuum lines. there's a thread on it in the link in my sig. Link to comment Share on other sites More sharing options...
gogmorgo Posted July 10, 2022 Share Posted July 10, 2022 Would lack of vacuum trigger the 4x4 light? I would expect it to be the opposite, no vacuum being no 4x4 light. But I could be wrong. The other likely scenario is the wire going to it is rubbed through and contacting ground. Link to comment Share on other sites More sharing options...
JWheeler331 Posted July 29, 2022 Author Share Posted July 29, 2022 On 7/8/2022 at 9:46 PM, Pete M said: another option is to shift the cab permanently and plug the vacuum lines. there's a thread on it in the link in my sig. Pete, I am not sure what you mean shift the cab permanently. I have looked through the list several times but I guess I am missing it. Link to comment Share on other sites More sharing options...
Pete M Posted July 29, 2022 Share Posted July 29, 2022 whoops, typo. that was supposed to say "shift the CAD". look under axles for CAD deletes. Link to comment Share on other sites More sharing options...
boxyjeep Posted July 29, 2022 Share Posted July 29, 2022 I removed all the CAD vacuum junk and switched over to an electronic indicator switch on the transfer case. Not too hard to do. Link to comment Share on other sites More sharing options...
gogmorgo Posted July 30, 2022 Share Posted July 30, 2022 7 hours ago, SoCalJeepComanche said: I removed all the CAD vacuum junk and switched over to an electronic indicator switch on the transfer case. Not too hard to do. Is that just swapping in the switch from a non-cad transfer case? I’ve always assumed this could be done, but never tried it myself. Link to comment Share on other sites More sharing options...
boxyjeep Posted July 30, 2022 Share Posted July 30, 2022 7 minutes ago, gogmorgo said: Is that just swapping in the switch from a non-cad transfer case? I’ve always assumed this could be done, but never tried it myself. no, you need to run the wire and tap it in. I did it. Works well. Link to comment Share on other sites More sharing options...
gogmorgo Posted July 30, 2022 Share Posted July 30, 2022 4 minutes ago, SoCalJeepComanche said: no, you need to run the wire and tap it in. I did it. Works well. Do you not just plug in the harness for the non-cad tcase up at the firewall? Pretty sure that’s all I did when I went to an NP242, but it was a while ago. I just wasn’t sure if you could just just pull the switch out of a non-cad np231 and direct swap it for the vacuum cluster thing in the older 231. Link to comment Share on other sites More sharing options...
boxyjeep Posted July 30, 2022 Share Posted July 30, 2022 Just now, gogmorgo said: Do you not just plug in the harness for the non-cad tcase up at the firewall? Pretty sure that’s all I did when I went to an NP242, but it was a while ago. I just wasn’t sure if you could just just pull the switch out of a non-cad np231 and direct swap it for the vacuum cluster thing in the older 231. You might be able to do that. I didn’t have a harness so made my own. Link to comment Share on other sites More sharing options...
