Ellis333 Posted July 1, 2022 Posted July 1, 2022 Trying to find out as much info about my 88 comanche. I put the vin in the title
eaglescout526 Posted July 2, 2022 Posted July 2, 2022 *X1 -SA Charcoal 3LW ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group AGP APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJN 15" Aluminum Wheels Build date 2/10/88 Body code JM61 Sold by KELLY CHRYSLER DODGE JEEP, EMMAUS PA
Ellis333 Posted July 5, 2022 Author Posted July 5, 2022 Appreciate all the info. Do you know What type of 5 speed came in it.
89 MJ Posted July 5, 2022 Posted July 5, 2022 31 minutes ago, Ellis333 said: Appreciate all the info. Do you know What type of 5 speed came in it. Based on the fact it is an 88 with a 4.0, it would have came with the horrid Peugeot BA10-5. In 34 years though, it may have been swapped for a (most likely case) much stronger AX-15
eaglescout526 Posted July 5, 2022 Posted July 5, 2022 Best way to tell which 5 speed is to crawl under and take a look. If the case is mated together like a clam shell, it is the BA10/5. If it looks more like a traditional trans case, it is the AX15.
Pete M Posted July 5, 2022 Posted July 5, 2022 peugeot = splits into a left and right half of the case AX-15 = splits into a front half and rear half. peugeot circled on the right:
Ellis333 Posted July 5, 2022 Author Posted July 5, 2022 Thank you I truly appreciate all the knowledge..
Ellis333 Posted July 5, 2022 Author Posted July 5, 2022 Unfortunately I got the bad one. What yrs and what type of donor jeep should I look for to do a swap for ax-15
Pete M Posted July 5, 2022 Posted July 5, 2022 '89.5+ 4.0L MJ or XJ or YJ or TJ. the wrangler transmissions are slightly different though so it depends on what you're doing with the truck as to whether it's wroth the extra work. you'll need the bellhousing and the guts, the trans mounts, the shifter handle, and crossmember. plus your current t-case has a 21 spline input and the AX-15 will have a 23 spline output so you'll need a t-case too. if your peugeot transmission works fine now, it should keep working fine in the future. just make sure you keep the oil level up and don't abuse it.
Ellis333 Posted July 6, 2022 Author Posted July 6, 2022 I will make sure I keep it in top shape. And honestly this comanche don't get drove much right now. Thanks for the info
