Emissions light is on and I'm getting around 12 mpg on a stock build (4x4 short bed i6). Saw some threads that the bosch unit doesn't run in closed loop. What other brands are good to buy?
First off, that light is triggered by a timer. It has no clue about anything else.
since you have an 88, I would suggest going to www.cruiser54.com and COMPLETING Tips 1 through 5 before buying any parts at all.
I plan to follow those tips but I was just curious as to what I should buy when I finally get to that point, as I don't think the sensor was ever replaced.
I've had good luck with Bosch sensors (the old style with the white/ceramic body) you can still find them on Ebay, part number 12009. If I could make a suggestion, I would suggest making absolutely sure the circuit to and from the O2 heater circuit is in great condition including the O2 heater relay. I had an issue with the wiring on mine that was driving me crazy, I even added a "backup" ground similar to cruisers fuel pump "backup" ground setup and the issues were solved, the O2 sensor plays a HUGE role in the way these 4.0's run and idle.
I'll definitely keep that in mind among cruisers tips as well
Do the Tips. You just may fix it in the process.
Aftermarket parts are hit and miss any more. NTK used to be the go-to brand, but I'm not sure that's still true.
Yeah, NTK uses a metal body now. Mine lasted less than a year. They're using a 4 wire sensor from another application that only kind of fits the specs, and splice 2 of the wires together to make it fit a Renix 3 wire. (I'm assuming this is the same thing Bosch did as a cost cutting maneuver) I bought a Crown from Quadratec and it looked identical to NTK.
Do Cruiser's tips first to make sure it is the o2 sensor, lots of things can contribute to poor mileage on a Renix.
The simplest route is to find one that still has a ceramic body. Lots of websites show a ceramic body in the pictures, but if you order it, a metal sensor shows up. Renix sensors use an older style o2 sensor element that is starting to disappear from the market.
I went a different route, but it requires one of Nick's Renix Engine Monitors. I use an AEM wideband AFR gauge, and send the 0-5V output on that to the REM to convert to a narrow band signal, then send that back into the ECU. I've been driving it since April and it's been doing great. If you already have a REM it costs about $200. Nick has been out of stock for a while now because of the chip shortage, but the REM is becoming a must have for a Renix.
I made a write up to make it easy to wire/set everything up correctly.
https://comancheclub.com/topic/68935-ditching-the-narrowband-o2-for-a-wideband-with-the-rem/
