kevinnjanetsjeeps Posted December 3, 2007 Share Posted December 3, 2007 :USAflag: whitneys has 2 of them but how do I tell which rears I have either the chrysler or danas I have nothing on them so I am a little confused by the differences also how can I tell which one to buy :USAflag: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 3, 2007 Share Posted December 3, 2007 :USAflag: whitneys has 2 of them but how do I tell which rears I have either the chrysler or danas I have nothing on them so I am a little confused by the differences also how can I tell which one to buy :USAflag: this belongs in tech. anyways, the dana 35 rear axle has an oval-shaped diff cover. the chrysler 8.25 rear axle has a circular cover. the dana 35 should be high pinion and the 8.25 is low pinion Link to comment Share on other sites More sharing options...
kevinnjanetsjeeps Posted December 3, 2007 Author Share Posted December 3, 2007 sorry still learning now I can't erase it Link to comment Share on other sites More sharing options...
Twisty Posted December 3, 2007 Share Posted December 3, 2007 :USAflag: whitneys has 2 of them but how do I tell which rears I have either the chrysler or danas I have nothing on them so I am a little confused by the differences also how can I tell which one to buy :USAflag: this belongs in tech. anyways, the dana 35 rear axle has an oval-shaped diff cover. the chrysler 8.25 rear axle has a circular cover. the dana 35 should be high pinion and the 8.25 is low pinion 1.) The D35 was never high pinion...only low pinion. ;) 2.) The 8.25 never came in MJs. Only the D35, and the D44. ;) Yours is a 1989, and if the diff cover is oval, its a D35, if it looks like this (see pic) then its a D44. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 3, 2007 Share Posted December 3, 2007 :USAflag: whitneys has 2 of them but how do I tell which rears I have either the chrysler or danas I have nothing on them so I am a little confused by the differences also how can I tell which one to buy :USAflag: this belongs in tech. anyways, the dana 35 rear axle has an oval-shaped diff cover. the chrysler 8.25 rear axle has a circular cover. the dana 35 should be high pinion and the 8.25 is low pinion 1.) The D35 was never high pinion...only low pinion. ;) 2.) The 8.25 never came in MJs. Only the D35, and the D44. ;) Yours is a 1989, and if the diff cover is oval, its a D35, if it looks like this (see pic) then its a D44. aha, you got me. you're looking at XJ (cherokee) lift kits. you need to not do that and look at the comanche ones. you'll need the Add-a-leaf for the comanche, and the rear shocks are all different. you probably have a dana 35. Link to comment Share on other sites More sharing options...
StevenH Posted December 3, 2007 Share Posted December 3, 2007 Get a set of spring perches for $12 and do a spring over. Link to comment Share on other sites More sharing options...
JEEPERZ Posted December 4, 2007 Share Posted December 4, 2007 there is always this Link to comment Share on other sites More sharing options...
rockhardzj Posted December 4, 2007 Share Posted December 4, 2007 2.) The 8.25 never came in MJs. Only the D35, and the D44. ;) Hmm... Wonder why mine has one then... :brows: Link to comment Share on other sites More sharing options...
comancheon33 Posted December 4, 2007 Share Posted December 4, 2007 2 of mine have 8.25s. :chillin: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 4, 2007 Share Posted December 4, 2007 because you put them in? Link to comment Share on other sites More sharing options...
comancheon33 Posted December 4, 2007 Share Posted December 4, 2007 Sure did I got 99 29 splinein my 91 and putting a 94 27 spline in the 88 but leaving it spring under this time at for now. Link to comment Share on other sites More sharing options...
rockhardzj Posted December 5, 2007 Share Posted December 5, 2007 Sure did I got 99 29 splinein my 91 and putting a 94 27 spline in the 88 but leaving it spring under this time at for now.98 29 Spline in my 88, and it's even got discs! :D:D:D Link to comment Share on other sites More sharing options...
90PioSport99 Posted December 5, 2007 Share Posted December 5, 2007 98 29 Spline in my 88, and it's even got discs! :D:D:D Heheh, Comancheon33's and mine do as well. Seems to be pretty popular around these parts. Link to comment Share on other sites More sharing options...
Rokhound Posted December 5, 2007 Share Posted December 5, 2007 98 29 Spline in my 88, and it's even got discs! :D:D:D Heheh, Comancheon33's and mine do as well. Seems to be pretty popular around these parts. I guess I am not specail mine has the 8.8 :brows: Link to comment Share on other sites More sharing options...
