Dickinson County Comanche Posted June 7, 2022 Author Share Posted June 7, 2022 EGR solenoid test came back ok. I have 19” at idle according to my vacuum gauge. Link to comment Share on other sites More sharing options...
Dickinson County Comanche Posted June 7, 2022 Author Share Posted June 7, 2022 I have a slight vacuum leak at the EGR itself. The intake side has a slight leak. Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 7, 2022 Share Posted June 7, 2022 After market O2 sensors seem to be garbage. If you probe between A&B of the connector on the sensor it should read 5-7 ohms, aftermarket (NTK, Bosch, Amix-Ada) ones are reading only 4ohms from what I’ve seen. Find an actual NOS Mopar one. Link to comment Share on other sites More sharing options...
Dickinson County Comanche Posted June 8, 2022 Author Share Posted June 8, 2022 56 minutes ago, fiatslug87 said: After market O2 sensors seem to be garbage. If you probe between A&B of the connector on the sensor it should read 5-7 ohms, aftermarket (NTK, Bosch, Amix-Ada) ones are reading only 4ohms from what I’ve seen. Find an actual NOS Mopar one. Tested my O2 sensor and got just over 0 ohms. Like probably .001 of an ohm. Definitely an issue there I’d say. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 8, 2022 Share Posted June 8, 2022 Take your meter and a can of Freeze-Off with you to the wrecking yard... Link to comment Share on other sites More sharing options...
Dickinson County Comanche Posted November 2, 2024 Author Share Posted November 2, 2024 Coming back after a while to say I have solved this, it was the coolant temperature sensor that was bad and causing it to not enter closed loop. My fault for using cheap Rockauto sensors, thing was probably bad out of the box. Link to comment Share on other sites More sharing options...
Duncan Moody Posted November 2, 2024 Share Posted November 2, 2024 Glad it's solved, and appreciate you posting the update. What make CTS did you finally use? Link to comment Share on other sites More sharing options...
Dickinson County Comanche Posted November 3, 2024 Author Share Posted November 3, 2024 20 hours ago, Duncan Moody said: Glad it's solved, and appreciate you posting the update. What make CTS did you finally use? I used the NTK EF0072. When I did the engine swap I relocated my sensor to the 91+ location. Link to comment Share on other sites More sharing options...
