Speedo cable has started leaking. It's the original factory one. One end is the plastic connector, but the one without the tab, and the other end is a nut.  Haven't been able to find what I need between the 2 ends. I see some of the replacements have a serrated connector on the trans side, not a nut.  Are they the same thread and size?  Factory is 4 cylinder ax4 2wd. Now it's v8 and tremec trans but the factory cable worked great.
The first 2 pictures are mine now. Then the last picture is all I can find for replacements. Nothing with the correct speedometer connector and nut on the same cable.
