Cushdaddy Posted March 9, 2022 Share Posted March 9, 2022 I am putting 1997 Cherokee seats in my 1989 Comanche. I bought the new seat brackets to weld in over the new floor pans. The question is, will the newer Cherokee carpet fit well in a Comanche? I have a 1998 Cherokee, and they look close enough to me. I called Stock Interiors in South Carolina, and they said they are a bit different. Just trying to make sure I don't waste $200. I know it will require cutting and trimming. I'm more interested in the trans tunnel and firewall areas. Link to comment Share on other sites More sharing options...
Cushdaddy Posted March 9, 2022 Author Share Posted March 9, 2022 I'm also putting the center console from a Cherokee in there, and the trans tunnel isnt exactly factory as seen below, so close is probably good enough. Link to comment Share on other sites More sharing options...
MiNi Beast Posted March 10, 2022 Share Posted March 10, 2022 Going to be a bit different for fitment per mold as floor pans and firewall are different. Custom carpet laid in and trim to fit with some foil sound deading should be more flexible to work worth. Otherwise clear it now as it looks sweet. Link to comment Share on other sites More sharing options...
Gjeep Posted March 12, 2022 Share Posted March 12, 2022 Only area that will not fit perfectly with 98 carpet will be the rear ‘step’ at back of floor / cab wall. Link to comment Share on other sites More sharing options...
ratrapp Posted March 13, 2022 Share Posted March 13, 2022 did you use rear cherokee floor pans for your replacements? Link to comment Share on other sites More sharing options...
Cushdaddy Posted March 19, 2022 Author Share Posted March 19, 2022 Yeah, just the key parts 84-01 pans, had to buy the 2 piece for the passenger side cause of lead time issues. I dry fit the Cherokee seats, and they seem a bit high. The bench seat seemed hight too. I'm thinking about cutting the seat brackets down an inch or so. I'm only 6'1", but feel like am staring at the top of the windshield. Link to comment Share on other sites More sharing options...
ratrapp Posted March 19, 2022 Share Posted March 19, 2022 i ordered mine and they got here friday.ive got the same problem being 6'1 as well. Link to comment Share on other sites More sharing options...
