1J7FJ66S0NL207591
ThreeComanches
1992 Jeep Comanche Eliminator
4.0L HO / AW4 4 Spd Auto / 4x4 / Dana 30 Front (3.55) / Dana 35 Rear (3.55) /  Short Wheel Base
Build date: 2/92
Current Location: North Alabama
Status: Ongoing restoration, runs and drives. End goal is to have it all as factory as possible.
Current Owner: Myself
Notes: Hunter Green Metallic exterior / Gray interior / cloth / vinyl bucket seats / floor shift. Had fog lights originally but were removed when the truck was wrecked at one point in its life. Truck has also had a respray at one point (hence the missing decals and trim).
Edit: as of October 2024, she underwent a complete exterior restoration (frame work, body work, respray) and has been sold to an elderly gentleman in Delaware.
20220304_175318.jpg.2cca846cef2043c605dce0b0bffb9a22.jpg20220304_175409.jpg.b01926a3e405b303e316b9f231a1ea0a.jpg20220304_175551.jpg.75d9e1a1bc18efc211a1593860832837.jpg20220304_175649.jpg.59d525946d4fded6bad261cd1dad6d55.jpg20220304_175604.jpg.4035b6fb8ded263b5e5013c89a8fd6ef.jpg892722542_ScreenShot2022-03-04at10_12_38PM.png.5738fcdcd50d85be991115dd6286a1bc.png
*Q7 Cloth Low-Back Bucket Seats
-SA Charcoal
161 Zone 61-Atlanta
1AA U.S. Dealer Retail
26H Customer Preferred Package 26H
2TH Customer Preferred Package 2TH
3VU
4EA Sold Vehicle
4M1
ADA Light Group
ADL Skid Plate Group
APA Monotone Paint
ARM Radio AM/FM Cassette
BAR 90 Amp Alternator
BCD 550 Amp Maintenance Free Battery
BGA Power Front Disc/Rear Drum Brakes
CAC Low Back Bucket Seats
CDB Reclining Front Seats
CKA Carpets - Floor and Cargo Area
CUF Full Length Floor Console
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHS Floor Mount Automatic Shift Lever
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ Dana 35 Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAY DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K27 Do Not Use
K2B STRIPE/BADGE/MOLDING/COLOR
K3G STRIPE/BADGE/MOLDING/COLOR
KLT
KWD
LAJ Headlamps On Warning Chimes
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE Ambient Light
LDA Underhood Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
LNJ Front Fog Lamps
MB1 Black Front Bumper
MBJ Black Bumper
MCA
MFK Body Color Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
NHM Speed Control
PG5 Hunter Green Metallic
QG5 Hunter Green Metallic Clear Coat
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TRN P225/75R15 OWL Wrangler AT Tires
TZA Goodyear Brand Tires
WJH 15X7 Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z83 Right Front Spring Group XII
Build date 2/26/92
Body code JL61
Sold by JASPER JEEP-DODGE-CHRY-PLYM, JASPER GA
9 minutes ago, The Technical Wizard said:
Thank you very much for this info!
I've edited out the common errors and reused codes.  sorry, but the truck never had rack-n-pinion or a powdercoated bumper.  :L:
  • 10 months later...
  • 4 months later...
17 minutes ago, WranglerMangler said:
Guess I need new bulbs. Those make mine look dim turned all the way up. Thanks.
check the condition of your headlight switch.  corrosion on the dimmer coil can cause problems too.
