eaglescout526 Posted January 27, 2022 Posted January 27, 2022 *W7 Cloth Lo-Back Bckt -H9 ADA LIGHT PACKAGE ADE COLD WEATHER PACKAGE ADL SKID PLATE GROUP AGL AHL HEAVY DUTY INSUL PACKAGE APA MONOTONE PAINT PACKAGE AWJ Visibility Group BCQ Battery - Maintenance Free CAC BUCKET SEAT CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGQ TRANSMISSION-4SPD AUTOMATIC DMR 3.55 Axle Ratio ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JDA SPEEDOMETER - 140 KILO PRIMARY JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL KQJ LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAG NFA TANK - 23 GAL FUEL NHB HVY DTY/AUX TRANS OIL COOLER NHK ENGINE BLOCK HEATER NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY PXB QXB RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT TBL TIRE CARRIER - INSIDE WJD WHEELS - 15 X 7.0 STYLED STEEL Z1B GVW/PAYLOAD RATING Build date 2/11/87 Body code JP62 Sold by LES AUTOMOBILES ESCRIVA, BLAINVILLE QC(QUEBEC CANADA)
fiatslug87 Posted January 27, 2022 Posted January 27, 2022 This is a Metric Ton Laredo, top of the line
ArcticMonkey Posted January 30, 2022 Posted January 30, 2022 Thank you Eaglescout! Much appreciated. Can I deduct from this that I have a normal radiator? (NMB Normal duty Cooling).. And how do you see its "tow package/metric ton"? Also, it seems my running boards are identical to the AMC running boards mentioned in Eaglescouts article, If I can show DMV that they were there originally, I can put back the lights in them...Could that be the Light package (ADA)Thanks.
fiatslug87 Posted January 30, 2022 Posted January 30, 2022 The “U” in position 8 of the VIN designates a Laredo metric ton.
ArcticMonkey Posted January 31, 2022 Posted January 31, 2022 Thanks fiatslug, where can I find all this information? ...or is it only me being mentally challenged? (bet it is...)
fiatslug87 Posted January 31, 2022 Posted January 31, 2022 @ArcticMonkeyThis information is in the Registry List spreadsheet (Excel) which can be downloaded.
