Sporrer Posted January 11, 2022 Posted January 11, 2022 Hello All, new to the club with a '88 and a NOOB to restoration. Teenage son wanted to dive into a project truck so I took the opportunity to spend time and have some fun. Bedsides have rust above the wheels and I am not sure what the best approach is. It is extensive so they must go. What should I look for at either a scrap yard or order a Key Parts Rear Upper Wheel Arch for 1986-1992 Jeep Comanche MJ [Right/Passenger Side] from Jegs? I will take a link to an existing conversation if one exists. Thanks in advance I look forward to moving on this project.
89 MJ Posted January 11, 2022 Posted January 11, 2022 I’d buy the Key Parts patches. Thread on rust repair: You can also check out my build thread for more rust repair info. Since bodywork and paint will be next:
Parei_doll_ia Posted January 11, 2022 Posted January 11, 2022 Key Parts would be a lot easier than what I did piecing together XJ wheel arches. XJ arches are both shorter and narrower, and the flare stamping is slightly different. I fabricated some patches of my own for the inner fender. XJ inner fenders can be used for patches there too.
Pete M Posted January 12, 2022 Posted January 12, 2022 definitely get the key parts panels. haven't heard a bad thing yet about them. but it'll likely need more repair on the inner section too, so be prepared.
Sporrer Posted January 18, 2022 Author Posted January 18, 2022 Got lucky and found a full bed at the yard with only a little damage, no rust so definitely the lesser of two evils, thanks for the responses will use the advice on a few smaller spots.
Pete M Posted January 18, 2022 Posted January 18, 2022 12 hours ago, Sporrer said: Got lucky and found a full bed at the yard with only a little damage, no rust so definitely the lesser of two evils, thanks for the responses will use the advice on a few smaller spots. lucky! beds are getting harder to find in usable shape.
Tex06 Posted January 18, 2022 Posted January 18, 2022 8 hours ago, Pete M said: lucky! beds are getting harder to find in usable shape. Somebody keep buying them all.....
