89 MJ Posted January 10, 2022 Share Posted January 10, 2022 Is there a good place that I should buy low pinion D30 gears from? I’ve heard of a few okay places, but I wanted to see if there is a solid consensus that I have just missed. Or any places to stay away from? Same with brand, any good or particularly bad brands? Note: Before I hear it for gearing a low pinion axle, I should note that this is for the Eagle, which had a low pinion IFS. Link to comment Share on other sites More sharing options...
scguy Posted January 10, 2022 Share Posted January 10, 2022 I've heard good things about Yukon, Motive and Revolution. I chose Revolution for my 8.8 and will likely use them in my D30 as well. Link to comment Share on other sites More sharing options...
Pete M Posted January 10, 2022 Share Posted January 10, 2022 same. those brands seem to get praise. we're sure that there's nothing weird about this front diff, yes? I ask because I know the Liberty dana 30a front diff is... different... and won't accept regular dana 30 gears. Link to comment Share on other sites More sharing options...
87Warrior Posted January 10, 2022 Share Posted January 10, 2022 I've had very good results from Yukon gear sets. Link to comment Share on other sites More sharing options...
89 MJ Posted January 10, 2022 Author Share Posted January 10, 2022 3 hours ago, scguy said: I've heard good things about Yukon, Motive and Revolution. I chose Revolution for my 8.8 and will likely use them in my D30 as well. 2 hours ago, 87Warrior said: I've had very good results from Yukon gear sets. Thanks guys! 2 hours ago, Pete M said: same. those brands seem to get praise. we're sure that there's nothing weird about this front diff, yes? I ask because I know the Liberty dana 30a front diff is... different... and won't accept regular dana 30 gears. I have not heard anything about it not taking standard D30 gears. I’ll double check though. Link to comment Share on other sites More sharing options...
