Cruise/Trans Switch
@cruiser54 Thanks for the photos.
Any help here on part numbers or replacement part numbers. I'm wondering if they use the same TCC Sw on vehicle with the same TRANS but w/CC or wo/CC. Again, anyone got part numbers for this?
I'm going to start looking for one under the WANTED section.
38 minutes ago, cruiser54 said:
Did you ever see my Cadillac switch fix?
No. What's that all about?
39 minutes ago, cruiser54 said:
TCC switch cuts the circuit when peal is depressed.
So, Electrical Schematic is wrong. Claims circuit is CLOSED (path to ground) when pedal is depressed.
Well, when I put a switch inline to the TCU, if the switch was closed, the TC would lock up.
Switch to open the switch and the TC wouldn't lock up.
When pedal is depressed, brake switch completes that circuit.
When pedal is depressed, the TCC circuit breaks.
Well, that make me believe the electrical schematic is wrong. Need to get a Cruise/Trans Sw. for final prove out. Thanks for the follow up.
