EagleEar Posted December 10, 2021 Posted December 10, 2021 Hello, During replacing the dash i found a few connectors which are not used, please help me with identification of it . Thanks in advance !!! 1. 2. 3. 4. 5 6 7 8
EagleEar Posted December 10, 2021 Author Posted December 10, 2021 1 - Transmission switch Power - will it work on manual ? 5 - instrument planel 6 - cargo light 7 - clock switch Please help with others.
jdog Posted December 10, 2021 Posted December 10, 2021 2 cruise 3 either speaker or well lights 4 headlight delay 5 gauge cluster 6 cargo light 7 clock 8 ? btw year is helpful if you fill out your signature it helps us out a lot
EagleEar Posted December 10, 2021 Author Posted December 10, 2021 Dear Jason, Many thanks for your help , the car is 88 , 2,5 liter , manual. I got 3 of MJ so even signature will not help No 8 was lying on the floor in the middle of cabin.
eaglescout526 Posted December 10, 2021 Posted December 10, 2021 Actually number 2 is the emission maintenance timer plug. Not cruise. No 8 looks like rear harness for the rear of the truck.
EagleEar Posted December 10, 2021 Author Posted December 10, 2021 Wow , thanks for quick help , it's amazing. I will buy this delay module for lamps and where is located emission timer ? What about number 3 ? I think there is no similar on other side so this is not speaker .
jdog Posted December 10, 2021 Posted December 10, 2021 You don't want the emission timer, it was a one time user item that would turn on a light. No use for it. It could have also been to a switch on the clutch or the brake for 3
acfortier Posted December 10, 2021 Posted December 10, 2021 You also don't need the delay for the headlights, either, if you don't want it.
