WTB: Spring plate/shock mount
Sir Sam
the shock mount is indeed different left to right (mirror image).  the brace that goes under it is the same on each side.
fun fact, the left and right mounts switch sides from longbed to short bed. :L:  (longbed shocks are in front of the axle, shortbeds are behind)
did not know that. That is a fun fact then.
4 hours ago, 500 MJ said:
I have a set of these that I would sell. Do you need the u-bolt stiffeners as well?
3 hours ago, Strokermjcomanche said:
What year ? What axle ? The 35 is 80mm , the 44 is 85mm . 91 and 92 are one piece , older are 2 piece
I just need the left side longbed…….but I have no idea if I have the correct one on the right side right now. Snapped a pic, you can see the right side, so I need the mirror of that one?
