Truck not having required power
7 hours ago, Muncher said:
Not sure I got a new ignition switch but now I can't even get the new one to turn over properly like the old one would
So you replaced the ignition switch and the starter relay? Did you adjust the ignition switch? Do you have power on the red wire
