Interior bits
eaglescout526
Here is where all the interior based parts for XJs and MJs will go. Remember, ALL parts will be CLEANED before shipping.
*Shipping for smaller parts is $4.
Larger parts may very.
Clock Delete plate. $5. Fits all years. 4 on hand*
Seat belt guide covers. $5* I think I have two garnet left
Grab(OH $#!&) Handles and pieces. $15 for a handle, $3 for the little covers, $5 for the little hook. 2 Cordovan Sold.*
Auto trans shift handles. $10*
Glove box light. $10* 1 in stock
Head lamp switches. $15* 3 in stock
Command-trac bezels. $10*
Auto trans floor shift indicator. missing the indicator portion but it seems this bezel can come apart. $10*
Door handle cup set. $15(Sold individually not all three, set referring to the lock button, handle and cup)*
Ash trays. $15*
97-01 XJ dash switches. $15*
Garnet passenger side visor and will include an MJ only harness. Lights do work. $50
IMG_8956.jpg.105cc00af31bb03eab35c7eaebf81fe3.jpgIMG_8958.jpg.06dcf1b8b67f14f53e848611d942cc5d.jpg
Charcoal pass visor. Mirror seems to have fallen out of place which is a new one by me. Will include an MJ only harness. If it’s for an XJ let me know. $50
Glove box door. $25 2 in stock
Seat adjuster handle knobs. $5 ea. 2 on hand.*
B-pillar MJ seat belt set. $75
Upper half of a limited XJ vinyl seat cover in what looks like charcoal. I spent a few days restoring this seat back to its color(no painting, only vinyl cleaner was used). The way I see it, this cover it probably only good for material use I.E. repairs to an already existing complete seat. I would hate to just toss it the wayside as it can provide use somewhere. $30. (looks to be from a 90 XJ)
XJ limited charcoal vinyl headrest. Spent a couple days restoring the color(no painting involved) of this headrest with vinyl cleaner. I think it turned out great. Perfect to replace your damaged head rest or paint over it to replace any other color headrest. $20. (looks to be from a 90 XJ)
Bucket seat foam wings possibly from a 90 XJ bucket seat. These are in great shape. Perfect to replace your worn out ones. $25.
MJ Bucket Pass side rail cover. $20.
Full console rear support bracket. $5.*
89+ Seat belt guide cover bolt plug NOS(have 2). $10* Oh and a rubber grey one as well.
Upper half of a pass side black power seat. It has the reclining handle and it has been cleaned as well. Vinyl looks to not have aged well but is in pretty good shape. $150.
Cig lighter socket $5. All are untested, most are in good shape with minimal rust. Not sure why in the hell I have them(and the lamps and brackets)but they are perfect if your socket isn’t working or destroyed.(13 in stock). I also have two that don’t have the mounting hole for the lamp.*
Cig lighter light. $5*(7 in stock) these all have been tested. All work but some have a couple burnt out bulbs.
Cig lighter plate/bracket. $5. (17 in stock) these will be cleaned before leaving my possession.
GM chime module. Tested, it works for the keys in but not seat belt. Pin out could be different for that but hey it’s not a buzzer. $20
High beam switches. Unsure if genuine or not, all look to be in good shape. $10 ea. These are for 84-88 less flash to pass feature. They are genuine. weather they work is unknown. Maybe I will test them when I get the chance.
Black shift handle. $10
Brake switch, Renix era, non cruise, $7
Chrysler era GM RA5 key ignition switch, very used, key is worn but not severe. $20
HO era Jeep chrome door handle bezels. $20 for ones with switches, $15 for ones without.
#1
#2
#3
#4
#5
#6
HO era Jeep chrome woodgrain door handle bezels. $25
#1
#2
  • 2 months later...
50 minutes ago, shortee1fourtee said:
I need a hi beam switch, I also need the selector on the column. Also do you have any exterior parts?
Shoot me a pm for the hi-beam switch. I don’t have a selector for the column though. I have some exterior stuff but not a lot.
  • 4 months later...
  • 4 months later...
