oldjeep Posted November 18, 2007 Share Posted November 18, 2007 Anyone know off hand how the under dash fuse box connects to the rest of the wiring? ie - is there a big plug that disconnects everything from it? My kids 90 comanche has some electrical issues in the fuse panel. A lot of corrosion and the fuses all seem to be at an angle - indicating to me that something has come apart. Link to comment Share on other sites More sharing options...
JOMJ87 Posted November 18, 2007 Share Posted November 18, 2007 Unbolt the fuse panel and theres a plug on the back. Theres also a plug on the firewall in the hood. right beside the master cylinder. Cole Link to comment Share on other sites More sharing options...
Eagle Posted November 18, 2007 Share Posted November 18, 2007 x2 what he said ^^^. There's a single bolt through the two halves, and IIRC the bolt is removed from the engine compartment side of the firewall. Link to comment Share on other sites More sharing options...
jtdesigns Posted November 18, 2007 Share Posted November 18, 2007 yelp,, take the small little bolt out from the engine bay ( 8mm I believe) then under the dash theirs two clips/hooks keep it together. I removed the washer bottle on mine to get to it better. I bet you the m/c has leaked and took out some of those little clips that hold the fuses in.. My truck had the craziest looking fuses in it when I started this jeep thing from the mc leaking.. Most of the fuses clips were cracked up and broken... Had them all fixed up in no time,,,,,, Thanks again Wildman!! :cheers: Link to comment Share on other sites More sharing options...
