Cali Steve Posted September 3, 2021 Share Posted September 3, 2021 Vacuum connector to throttle body has a leak. Can we still get these or is it better to run individual lines instead?  Thanks for the advice Link to comment Share on other sites More sharing options...
jdog Posted September 3, 2021 Share Posted September 3, 2021 @eaglescout526 looks like a 2.5 Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 3, 2021 Share Posted September 3, 2021 It is. It’s an 86 so it’s a very very odd duck. Ive never looked into that part as the later years go to just single hoses but I can see if that’s something that was available. Link to comment Share on other sites More sharing options...
Big Dan Posted September 3, 2021 Share Posted September 3, 2021 Hopefully eaglescout will be able to locate something. On mine, I ended up running individual lines. Sent from my Pixel 4 XL using Tapatalk Link to comment Share on other sites More sharing options...
eaglescout526 Posted September 3, 2021 Share Posted September 3, 2021  I am not seeing it as a serviceable component sadly. No new harnesses are out there either. So probably some RTV may not be a bad idea for getting the block to seal right. Or the block can be done away and just straight pipe. I sadly don't have an 86 and have only worked with 3 86 2.5Ls in my life. It must also be a sought after vac line as when I was in Prescott Valley last weekend I found a 4 door 86 that didnt have any lines but just the manifold. Damn I need to go back to that yard. Link to comment Share on other sites More sharing options...
Cali Steve Posted September 8, 2021 Author Share Posted September 8, 2021 Thanks! Looks like I'm running some vacuum lines tomorrow! Link to comment Share on other sites More sharing options...
