I just bought this 88 sport truck on Hawaii. It’s the first Jeep I’ve owned and hopefully the last. I’m not much of a mechanic but I know it’s gonna need some fixing.
There seems to be an oil leak from the valve cover gasket. I bought a silicone gasket and installed it today. So far there are no leaks. There seems to still be an oil leak somewhere else though.
Nice looking truck! Get ready for something always leaking :laugh:
Most of these motors leak oil in 3-main places: Valve Cover, Oil Pan/Filter Adapter, and Rear Main Seal.
I'm currently restoring one that has almost 300k miles and the amount of crud covering everything is unreal. The first step is to clean (I know, it sucks) as much of the front as possible if you want a good chance at diagnosing any leaks that aren't vacuum or otherwise.
So I recently came across an older former Comanche owner. He sold me some parts for 300$. He sold me 2 aluminum radiators, one came with 3, 9” fans. A pair of taillights, sparkplugs, sparkplug hoses, distributor cap, ball joints, a new cluster w tac, and carpet. At the moment I’m still converting to open cooling and am waiting to find a larger alternator for the 3 fans ( I’m trying to find an alternator cheaper than the mean green). I also did the CAD delete, changed the calipers and rotors, fixed the lock in my truck, ordered new hardware for the drum brakes, changed the rear main seal, fixed the flattened transmission and engine oil lines and did a bunch of sanding and sprayed rustoleum on brake parts, axels, and some engine parts. I’m also installing a new thermostat and water pump.
