1988 MJ 2WD 4.0 Exhaust Hanger Help
Hello All,
I have a 1988 2WD 4.0 long bed. Last weekend I changed out the exhaust replacing with stock parts by Walker. The tail pipe at about mid section has two metal rods that attach to the rubber hanger that is attached to the body with another metal rod (x2). My problem is on my truck the metal rods that attach to the truck body are missing. I found a photo of the same exact truck that is in stock condition and best I can tell is the rods are attached to a plate that might be bolted to the body. I am not seeing any broken welds on the body so I am guessing they are bolted. Does anyone know the part number for this hanger? Where to find one? Anyone have a better picture so I can have something more to go off when looking for a replacement?
Any help would be great. Thanks in advance. 457548863_exhausthanger.jpg.cfdc136eb4f1295a4274ca75a35bfbe8.jpg
4 minutes ago, 88manche2wd said:
If anyone parting out a truck and has this part please PM me. I would post in the wanted section but I still don't have enough postings.
Thanks,
Nathan
Your just 4 post shy of getting access,  have you started a build thread?
Need to, not yet. I am just getting parts and info at this point. I did do the exhaust but not anywhere near done. Will get started on that build thread soon.
12 minutes ago, jdog said:
You can always start it and get your info.
What kind of exhaust did you go with.
I am just doing stock build. I used walker exhaust parts and replaced from the y-pipe to the tail pipe. Not done until I get the tail pipe hanger and correct bolts for the cat. I might have to rig something until I can find a oem tail pipe hanger or have one fab. I went with a cat before knowing that my truck had the resonator. I figured that out after finding a download of the parts catalog online this week. I ran the truck in place with the setup and was running fine. It's light years ahead as the prior owner had the wrong muffler piped in and everything was being help up with baling wire. It did not even have a tail pipe. It was loud and not producing any real back pressure.
42 minutes ago, jdog said:
It's always nice to see what it looked like and the transfermation it has made.
Walker is the same stuff I used when I redid mine, albeit mine didn't have bailing wire
I'm trying to keep mine wire free now also. lol
I just put the full walker kit on my truck.  I must say I am really impressed with the improved driveability.
I have a 92 parts truck that might have the hanger on it yet.  Ill look today and see what I have.
Btw your only one post away from the classifieds now. :comanche:
