How to use a auto column in a manual
So you just swapped a ax15 into your automatic truck but didn't get the manual column?
someone tried attempted to remove your comanche from your possession but couldn't figure out your kill switch and all that you can find are auto columns?
well here is a lengthy write up ( with pictures of course) of how you can remove the shift lock out from that auto column.
(not so fun part, I claim no responsibility if you screw it up, you are doing this at your own risk. I am only showing you a way to remove the interlock and nothing else.)
step one: remove the column from the truck. ( lots of write ups on how to remove the column)
step two: remove steering wheel
step three: remove the lock plate cover
step four: remove the lock plate using the lock plate removal tool
Step five: remove the turn signal cam
Step?? (takes off shoe) 7: remove ignition cylinder20210619_165604.jpg.c708481066450f5114ea2a39c2d6af4a.jpg20210619_165344.jpg.94b76e44577cad0990f58d369d6969f3.jpg20210619_165617.jpg.05b95784b8ab109ab93116990bdf3361.jpg
step 8: remove upper bearing( becareful these things break)20210619_165654.jpg.708dd2d2b6aee8f0e4d7776c8b88c15b.jpg
step 8: remove 3 t-30 torx bolts20210619_165351.jpg.b262de417b7ea9e48f345f0f8f411623.jpg
step 9: remove sleeve, remove turn signal switch and high beam cam20210619_165911.jpg.733fc6375fae104383efe56d69205041.jpg20210619_165913.jpg.d95b9c1cb6273f32ec526940f2047b24.jpg
step 10: tilt column all the way up and remove square plug using a Philips head screwdriver20210619_170054.jpg.d4175efe75867f1c4e6ba6d58c147704.jpg
20210619_170051.jpg.0877a70d521ddcf57cd642edf57fc458.jpg20210619_170103.jpg.eb68bd2a72390a4298eb1d6aa034536e.jpg
step 11: remove spring behind plug20210619_170109.jpg.2cfcbc0c854e1aaf2509cd91bf351daa.jpg
step 12: remove two plugs?? on side of column20210619_170237.jpg.743e66405f4af1faf381282429178900.jpg20210619_170241.jpg.da53e61d6bd1f9b20468e6fc97d12c1c.jpg
step 14: remove tilt assembly20210619_170346.jpg.bcf6003aa6dcd83eb7969ca511ff1cb3.jpg
step 15: remove shaft20210619_170555.jpg.118f75f0610dee4864af4130503659f4.jpg
step 16: remove 4 bolts and lower collar20210619_170613.jpg.bb778d5fa59a24b11f661a0390e99a34.jpg
step 17: remove nut plate20210619_170933.jpg.9d178122eba25ef59bbbbddd19efea6e.jpg
step 18: pull up on last collar20210619_171230.jpg.efefceaacc5066053b31ea44abc2fd15.jpg
step 19: remove rods(pull)20210619_165520.jpg.7bb2d00b33055343746d93bb22556897.jpg20210619_170847.jpg.13097ec8487b5bc60d2cd2280174e496.jpg20210619_171126.jpg.725cd67768f4384f11f8d9e8d9fa02c3.jpg
step 20: remove detent20210619_180830.jpg.13eae9980d50598944ade02d27e95e89.jpg
step 21: reassemble reverse order
First one i did it took me a couple hours, this one around a hour
  • 4 months later...
I just saw this today, but I'm SO glad someone did this since I'm working on swapping an AX15 in my auto truck!  So the whole point of this is just to remove that little white detent in those pictures?  That's all that stops you from being able to remove the key?  That and the rods that make it work?
  • jdog changed the title to How to use a auto column in a manual
