Power steering loss
I was just driving my truck and all the sudden i lost my power steering I belive. Really hard to turn the wheel. Only noise I heard from the steering was a weird sound when turned all the way to the left or right. I also checked under my truck and didn't see any fluid leaking or anything. Whay could this be?
1 minute ago, JustEmptyEveryPocket said:
Sudden loss of power steering, combined with how the squealing stopped means this should be the first thing to check. Don't run the truck too much without the belt as you also have no cooling and no charging.
Yeah I'm going to check thay right when I get home
If it's squealing at full lock, that means the pump is still turning and loading up.  It also means you should probably tension the serpentine belt, because the squealing is usually the belt slipping under load.
