I need the compressor to condensor line for my 88' 4.0 MJ.
I believe this is a one year only system, it has a different electric fan, and completely different AC system and I've only seen this setup on multiple 88's.
The line I need is a flare nut on tte compressor side and a open hose to a barbed inlet on the condensor.
I’m pretty sure I have one
Does the condensor side end with a hose and a clamp?
Just looked, It doesn’t. Ends in a fitting that screws into the condenser
I believe there was two different systems, one dealer and one factory installed.
If you can post a picture I bet someone has one laying around
I'd have to find my old one. But it'll be obvious if it's right as it's the only AC line they used that was just clamped on one end.
You're likely right about it being dealer installed but I've only ever seen them on 88's. Four so far to be exact and I'm always looking.
If I could remember where I put it I could probably just get one made.
