Kike Posted June 1, 2021 Share Posted June 1, 2021 Hi guys, so today I replace my horn relay and it burn and now my manche will not start, battery good I have lights but no start no radio looks like I fried something, any ideas? Thank you in advance Link to comment Share on other sites More sharing options...
jdog Posted June 1, 2021 Share Posted June 1, 2021 Check the ignition switch on the column (about halfway down the column) Link to comment Share on other sites More sharing options...
scaleless Posted June 1, 2021 Share Posted June 1, 2021 Does it crank with no start or does it not crank at all? Link to comment Share on other sites More sharing options...
Kike Posted June 1, 2021 Author Share Posted June 1, 2021 It does not crank or anything at all Link to comment Share on other sites More sharing options...
Ωhm Posted June 2, 2021 Share Posted June 2, 2021 Check your Fusible Links on the Starter Relay. Link to comment Share on other sites More sharing options...
Kike Posted June 2, 2021 Author Share Posted June 2, 2021 1 hour ago, Ωhm said: Check your Fusible Links on the Starter Relay. I am sorry for my ignorance but how do I check the fuse links? Link to comment Share on other sites More sharing options...
Kike Posted June 2, 2021 Author Share Posted June 2, 2021 I am sorry for my ignorance but how do I check the fuse links? Link to comment Share on other sites More sharing options...
jdog Posted June 2, 2021 Share Posted June 2, 2021 Easiest is to grab both sides and tug, if bad they will come apart. Next best thing is to ohm out each wire Link to comment Share on other sites More sharing options...
Kike Posted June 2, 2021 Author Share Posted June 2, 2021 You guys were right it was one fuse link fried, it is working! thank you Link to comment Share on other sites More sharing options...
jdog Posted June 2, 2021 Share Posted June 2, 2021 Hope you replaced it with another fuse link or a fuse holder Link to comment Share on other sites More sharing options...
Kike Posted June 2, 2021 Author Share Posted June 2, 2021 I will do it tomorrow I just checked and is running, thank you once again Link to comment Share on other sites More sharing options...
Kike Posted June 2, 2021 Author Share Posted June 2, 2021 I am sorry guys one last question the fusible link gauge 14 will be ok or which one so I need? Link to comment Share on other sites More sharing options...
jdog Posted June 2, 2021 Share Posted June 2, 2021 Depending on which one was blown Link to comment Share on other sites More sharing options...
cruiser54 Posted June 2, 2021 Share Posted June 2, 2021 Link to comment Share on other sites More sharing options...
Kike Posted June 2, 2021 Author Share Posted June 2, 2021 Thank you guys changed fuse link and Manche is running like new! Link to comment Share on other sites More sharing options...
