1JTMW64P6JT196762
Pete M
Hi,
Please advise if those doors from lift model 1997-2001 (red one on photo below)  Cherokee after removing those plastic trims will fit to it and keep line with trunk and fender edge.
What about rear lights , are they the same as Cherokee ?
Another question is window mechanism, here are mostly electrical ones , original are manual, can I later fit manual lifting to electric version ?
the MJ doors are the same dimensions and have the same lines as the front doors of a 4dr Cherokee.  but in 96 the door striker changed so you'll need to swap it.
taillights are different and do not swap without metalwork.
there are some good door/glass swapping threads in here:
*X4
-H9
3LX
AGJ Driver Assistance Group
APA MONOTONE PAINT PACKAGE
BCQ Battery - Maintenance Free
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
DDJ 5SPD MANUAL TRANS
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GFD SLIDING RR WINDOW
GSC MIRROR - RIGHT BLACK
HAA AIR CONDITIONING - FRONT
JFH TACHOMETER - MECH
JGB Clock - Digital
JHA WINDSHIELD WIPERS - DELUXE
JJA CIGAR LIGHTER - FRT COMP
K60 BODY SIDE MOLDINGS - VINYL
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MBJ Bumper - Front, Black
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NHQ Transmission Heater
PWB
QWB
RAB Radio - AM/FM
SBA POWER STEERING
SCE STRG WHL - EURO/SPORT TYPE
SUA TILT STEERING COLUMN
TBG SPARE TIRE - COMPACT
WJD WHEELS - 15 X 7.0 STYLED STEEL
Build date 5/2/88
Body code TM61
JASPER JEEP-DODGE-CHRY-PLYMOUTH, JASPER GA
