highctry Posted November 11, 2007 Share Posted November 11, 2007 I have a 90 MJ, it has bucket seats in it but they are not orginal. I have no idea what they are from but they do not fit the vehicle. I would like to replace them with another set of bucket seats, would I be able to replace with a set from a XJ. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted November 11, 2007 Share Posted November 11, 2007 yes but from a 2 door xj so that they still tip forward. that way you have access behind the seats. Link to comment Share on other sites More sharing options...
89mjpioneer Posted November 11, 2007 Share Posted November 11, 2007 If you don't have buckets will they still go right in? Link to comment Share on other sites More sharing options...
Pete M Posted November 12, 2007 Share Posted November 12, 2007 You will need to adapt whatever non-MJ seat you find to the floor brackets in the MJ. Fortunately the MJ bucket and MJ bench seats both use the same floor brackets. :D Link to comment Share on other sites More sharing options...
jaekl Posted November 12, 2007 Share Posted November 12, 2007 Has anybody take a look at Renault seats? The pedestal seat was a big sales pitch for Renault. Alliance is the model. Link to comment Share on other sites More sharing options...
Jeepinmanch Posted November 12, 2007 Share Posted November 12, 2007 I just swapped my bench out this weekend for some buckets out of a 86' manche. Shoulda done this a year ago! The only issue I found was that the seat belt buckles between 86' and 89' changed. :nuts: . To bad becouse the 86' ones had a cool AMC logo on the buckles. Link to comment Share on other sites More sharing options...
Pete M Posted November 12, 2007 Share Posted November 12, 2007 That brings up another tip: the female side of the seatbelt buckle has a plastic sheath around it in a bucket equipped truck, but doesn't in a bench truck. It just means that with no mods, the female side might fall down between the seat and center console (and that full center console can easily swap from an MJ or XJ if you grab the brackets that hold the it to the transmission tunnel). Link to comment Share on other sites More sharing options...
DirtyComanche Posted November 12, 2007 Share Posted November 12, 2007 The falling down seatbelt thing annoyed me enough that I ditched the centre console. I'd like to see people look for better seats than the XJ ones... I've seen ZJ seats swapped in. Link to comment Share on other sites More sharing options...
Eagle Posted November 13, 2007 Share Posted November 13, 2007 I'd like to see people look for better seats than the XJ ones... I've seen ZJ seats swapped in. So have I. It wasn't pretty ... Link to comment Share on other sites More sharing options...
